by MichaelFarley56 » Tue Oct 29, 2013 8:06 pm
Hey Bryan,
A few quick questions:
First, what did you set as your compression ratio? Are you at 8.0 to 1? Also, what prop are you using? The standard Sonex recommended 54x44, in either Sensenich or Prince? What is your field elevation? Which air filter are you using? Is the engine running smoothly?
To me, 2750 RPM at full throttle is a little low. If it's over 2900 I wouldn't be worried but this could be any of a few possible issues. First, your throttle cable may not be allowing full aeroinjector throttle plate movement. I would consider removing the air filter to check for throttle travel, and while it's off, do a quick test run without the filter. If that's an issue (dirty filter) that could be causing some of your problems. If that's not the case, I'd next focus on the injector needle.
I'm using a "stock" (unmodified) #2 needle in my AeroInjector as well. I'm sure you've read the manual and know where to start adjustments, but just for the fun of it I'd run through the tuning procedures again. What sort of RPM rise/loss are you seeing when you're at full throttle and full rich mixture and slowly lean out the mixture? As a guess I'd also venture out and say you're maybe a little lean for the conditions. I try to keep my needle adjusted so I don't see much over 1200-1250 max EGT during a full throttle, full rich mixture climb. That's what the factory recommended for me. I'm sure you've read it, but making small needle adjustments of 1/8 of a turn can make a big difference.
Don't be surprised if you need to lean out the mixture at low power operations like taxi and idle. That's pretty common. I for one will have my mixture leaned almost halfway of the travel (maybe 1.5" or so) during taxi and even during a run up, and as i taxi onto the runway i go full rich. Then again after landing as i make the runway turnoff, I'll re-lean the mixture. If you do that, does your engine still run okay?
As for the oil leaks...join the club! Those "accordion" style pushrod covers are okay, but I will always have a small drop of oil leaking out of at least one every time I pull the cowling. If it's a tiny leak and it bothers you, a small dab of red RTV will probably fix it, but if it's a big leak like you're describing the only simple fix I can think of is to remove the head, stretch it back out, and re-compress when you bolt the head back on. Sort of like killing an ant with an AR-15! A call to Kerry on the Sonex tech line may also offer you more clues. Is the tube going straight into the engine case? You can force a little movement out of them if the tube is sitting at an angle; you want them straight against the case.
Sorry I can't help more...hopefully others can chime in some ideas as well.
Good luck and keep us in the loop!
MichaelFarley56 on Tue Oct 29, 2013 8:09 pm, edited 1 time in total.
Waiex #0056 - N569KM (sold)
Onex #245
