Hydraulic Brake Bleeder Valve Orientation
Postby Direct C51 » Fri Sep 25, 2020 4:31 pm
I'm finally getting rid of my squeaky, sticky, pulsing, inadequate drum brakes and installing the Sonex hydraulic brakes. I noticed on the updated drawings that the brake body assembly (caliper) is mounted upside down for the taildraggers. I've attached a picture. This means the bleeder valve is no longer the high point, above the pistons. Has anyone mounted theirs like this? Has this caused any troubles with bleeding the brakes? I would assume you would have to pressure bleed them, instead of the method in the instructions where you pump, hold the lever, release the air, repeat.
Direct C51
Re: Hydraulic Brake Bleeder Valve Orientation
Postby racaldwell » Fri Sep 25, 2020 8:36 pm
I did not mount mine this way. I went with conventional: Bleeder valve on the bottom and brake fluid line at the top.
A pressurized tank is used to fill the system. All air is pushed up with the rising fluid.
Every plane I've had used a similar system and I want to use something that I know works satisfactory.
Rick Caldwell
Xenos 0057
racaldwell
Users browsing this forum: WolverineYX and 75 guests
