mike.smith wrote:Different conditions will give different results, but in level flight with my AeroVee I can cruise WOT at 130 kts (burning a LOT of fuel). That's about 149.5 mph. I don't generally run like that except for short bursts, or I feel like I'm whipping the "horse" to death. I generally cruise at max 100 kts or 115 mph, at just under 3,000 rpm. My taildragger weighs 673 lbs empty, and I'm running a Prince P-Tip prop. Math or no math, those are the numbers I've gotten over the last 6 years and nearly 500 hours.
peter anson wrote:According to the Jabiru installation manual, Jabiru 3300 cruise speed is 2750 to 3100 rpm. I do normally cruise at around 2750 rpm and speed is around 120 to 125 knots - 138 -144 mph. 3100 rpm should push the speed up to around 140 knots but fuel consumption would be pretty high. For range, I don't think I have ever tried for more than 280 nautical miles, about 320 miles.
Direct C51 wrote:mike.smith wrote:Different conditions will give different results, but in level flight with my AeroVee I can cruise WOT at 130 kts (burning a LOT of fuel). That's about 149.5 mph. I don't generally run like that except for short bursts, or I feel like I'm whipping the "horse" to death. I generally cruise at max 100 kts or 115 mph, at just under 3,000 rpm. My taildragger weighs 673 lbs empty, and I'm running a Prince P-Tip prop. Math or no math, those are the numbers I've gotten over the last 6 years and nearly 500 hours.
Mike, what pitch prop do you have? I would imagine the Prince is closer to 46” in cruise. What RPM are you at when flying 149.5mph? 3800? I’m not trying to be condescending, but do you find you more often have a headwind when compared to your GPS ground speed?
Direct C51 wrote:Peter, looks like we are in agreeance and your real world experience proves my math. I predicted 142mph at 2750 RPM and you confirmed 138-144 mph. I agree, 3100 RPM should give you 140 kts/160mph. Is that a normal cruise RPM for a Jab? Still 10 mph less than published cruise numbers.
Users browsing this forum: WolverineYX and 47 guests
