Drilling inside elevator rib to horn
Postby Darick » Sat Oct 12, 2013 3:59 pm
Am I being too particular? I drilled just two holes into each inside elevator rib to attach to the elevator horn. There is not enough room to get my drill perpendicular to all the holes, although it could be done at a slight angle. It seems to me a 90 degree drill attachment would be the right tool for the job. Is that what other builders have done?
Darick (just starting to build the tail)
Darick Gundy
Sonex #1646
N417DG
First flight! 10/21/2017
Darick
Re: Drilling inside elevator rib to horn
Postby onex28 » Sat Oct 12, 2013 9:34 pm
I've used an angle drill from Harbor Freight and also an 8 or 12 inch #30 drill that will flex slightly.
onex28
Postby Darick » Sat Oct 12, 2013 11:12 pm
Thanks. Looks like another trip to the HF aviation store is in order.
Darick Gundy
Sonex #1646
N417DG
Darick
Postby Bryan Cotton » Sat Oct 12, 2013 11:30 pm
I have one like this, but clunkier. One of my favorite tools.
http://www.aircraft-tool.com/shop/detai ... ID=A601KIT
I bought one of these and it is great too:
http://www.yardstore.com/browse.cfm/4,6738.html
Postby Mike53 » Sun Oct 13, 2013 6:44 am
onex28 wrote:I've used an angle drill from Harbor Freight and also an 8 or 12 inch #30 drill that will flex slightly.
:idea: The long bits are the low cost solution, it works great and will get a hole drilled in some very tight places.The 12 " is the best for flexing.
Mike
Mike
Antoine de Saint-Exupery
Mike53
Return to Sonex
Users browsing this forum: Google [Bot] and 7 guests
