Upper Cowl to Windshield Skirt Fit
Re: Upper Cowl to Windshield Skirt Fit
Postby Spaceman » Wed Jun 17, 2020 5:31 pm
It's called out in the plans but I want to say it's 6.5"
Chris Paegelow
http://paegelow.blogspot.com/
Spaceman
Postby Spaceman » Fri Jun 19, 2020 11:38 pm
Just to close the loop on this one, here's what I ended up doing:
I just cut through the little strip of the windshield skirt, right in the center.
Then all I had to do was file a tiny amount of material off of each side (like less than 1/32" I'd say), until the two sides could sit flat next to each other, then I riveted each side to the firewall flange.
That's it! The little seam is not perfect, but it's a lot less noticeable than that giant bulge was.
Chris Paegelow
Spaceman
Return to Sonex-B / Waiex-B
Users browsing this forum: No registered users and 31 guests
