Upper Cowl to Windshield Skirt Fit
Postby Spaceman » Mon Jun 15, 2020 12:40 pm
Howdy guys,
I'm working on my cowl. The lower cowl went on and fit well with pretty minimal effort, which was awesome, and now I'm working on the upper cowl. For the most part it also fit pretty great right out of the box, EXCEPT where it slides under the windshield skirt.
I think the problem is the front edge/flange of the skirt is a little bigger than the cowl so it doesn't sit flat against the fiberglass.
I noticed the skirt didn't really sit totally flat on top the of the firewall in the center back when I installed the upper firewall, so I figured I'd have to address it somehow when I got to the cowl. Now that the cowl is on it's a lot more obvious though!
Has anyone else run into this and found a good method to fix it? I definitely need to make the center of the windshield skirt flange come down, so I'm thinking maybe cut through the little strip in front of the fuel door so the two sides can come down to the top of the firewall, and then remove whatever material overlaps so it lines up again. Any other better way to do it?
Here's a photo. It looks bad but I think it's only about half as bad as it looks. The middle of the windshield skirt bulges slightly above the top of the firewall, and the cowl sits slightly below the firewall in the center since there's nothing holding it up in the center yet. I guess I just need them to meet in the middle.
Chris Paegelow
http://paegelow.blogspot.com/
Spaceman
Re: Upper Cowl to Windshield Skirt Fit
Postby Spaceman » Mon Jun 15, 2020 12:44 pm
Also, this is much less egregious but I think all stems from the same issue that the windshield skirt is a tiny bit larger than the cowl, but I ended up with a couple small bulges at each corner where it goes around the curved part. I'm not sure what, if anything, I can do about that!
Chris Paegelow
Spaceman
Postby Area 51% » Mon Jun 15, 2020 1:55 pm
Do you have any kind of anti-chafe tape between the cowl and firewall flange? I needed to use the thickest stuff I could find to get the cowl to match up to the windscreen.
I have a Legacy so this may not apply.
Postby Spaceman » Mon Jun 15, 2020 3:58 pm
Area 51% wrote:Do you have any kind of anti-chafe tape between the cowl and firewall flange? I needed to use the thickest stuff I could find to get the cowl to match up to the windscreen.
Not yet but that's on my shopping list! That will probably help with the smaller little bulges I guess, I hadn't though of it that way. What did you end up using? It's on my list but I haven't even gone looking for it yet
Chris Paegelow
Spaceman
Postby Rick524 » Mon Jun 15, 2020 9:21 pm
Hi Chris, on my legacy Sonex, I used a strip of black gorilla tape on the ledge that the cowl sits on.
It has been there for two years and looks and stands up fine.
Rick
Sonex 524
C-GRIX
Rick524
Postby Bryan Cotton » Mon Jun 15, 2020 9:49 pm
Rick524 wrote:Hi Chris, on my legacy Sonex, I used a strip of black gorilla tape on the ledge that the cowl sits on.
Rick
Sonex 524
C-GRIX
Me too.
Postby dirkverdonck » Tue Jun 16, 2020 2:57 am
Hi,
Is the use of a shrinking tool on the edge of the windscreen skirt an option?
I'm not into fitting the cowling yet but I used my shrink tool on the inner contours of the skirt to make it fit better with the windscreen itself.
Dirk Verdonck
Leffinge, Belgium
Onex #117
dirkverdonck
Postby Spaceman » Tue Jun 16, 2020 11:53 am
Shrinking tool, I'm not familiar with that one! Like fluting pliers?
Chris Paegelow
Spaceman
Postby wlarson861 » Tue Jun 16, 2020 12:05 pm
Bill Larson
N861SX
wlarson861
Postby Paul Johnson » Wed Jun 17, 2020 1:46 pm
Spaceman wrote:Howdy guys,
Hi Spaceman,
I know this is a bit of a thread drift but could you tell me the diameter of the wooden disc that is simulating the spinner rear plate.
Regards
Paul Johnson.
Paul Johnson
Return to Sonex-B / Waiex-B
