by Lbrandt » Sun May 31, 2020 4:45 pm
I’m having trouble reading oil pressure on my old Statomaster Ulta. I have the Standard oil temp sender and the 8b RDAC. This system is old I know that but it has always worked well until this.
The lead from the sender to the RDAC is new. The sender has been tested and is working.
The programming is the Stratocaster is set correctly but when I run the Jabiru the oil temp just flashes.
The unit seems to hold programming so the back up battery is still good. Any help will be greatly appreciated.
Lbrandt
Return to Electrical System
