Taper pin reamer
Re: Taper pin reamer
Postby Sonex Foundation » Fri May 01, 2020 6:28 pm
Spaceman wrote:I found it! Bill if you want to PM me your address I'll get it in the mail next time I leave the house.
Chris, there is a builder looking to borrow it. Gabe DeVault.
Gabe. I believe Chris has the taper pin reamer.
President
Sonex Builders and Pilots Foundation
http://www.Sonexfoundation.com
Sonex Foundation
Postby bvolcko38 » Sat May 02, 2020 10:27 am
Spaceman. I PMd you
Bill Volcko XNS0068
Aerovee and Prince P-Tip
V6
First hole 4/1/16
First flight 8/24/18
Phase I complete...finally!!!
bvolcko38
Postby pappas » Sat May 02, 2020 4:21 pm
Her's another likely dumb question. What is the advantage of using a taper pin in that assembly? What's wrong with a bolt and nut?
Lou Pappas
Phoenix, AZ
RV-7A Flying (2024)
Waiex B Turbo (2016)
RV-8 (2009)
Waiex Legacy 3300 (2007)
Hiperlight SNS-9 (1991)
Falcon Ultralight (1989)
pappas
Postby Spaceman » Sat May 02, 2020 4:53 pm
I guess it just makes a real snug connection that won't possibly loosen later and create any slop. I didn't know any of this existed until I encountered it on the plans!
Chris Paegelow
http://paegelow.blogspot.com/
Spaceman
Postby Sonex Foundation » Sat May 02, 2020 6:41 pm
http://www.sonexfoundation.com/uploads/ ... lation.pdf
For anyone interested in the why or how of the taper pin, Eric Seber wrote this up.
President
Sonex Foundation
Postby pappas » Sat May 02, 2020 8:09 pm
Robbie,
Thanks, an interesting read.
However, my personal OCD requires a bolt head on one side and a nut and washer on the other! I just know that slippery little bastard would escape with no bolt head!! I would have to check it 25 times a day!! ;-)
Lou Pappas
Phoenix, AZ
RV-7A Flying (2024)
RV-8 (2009)
pappas
Postby Sonex1517 » Sat May 02, 2020 10:45 pm
Fair enough Lou! I can totally understand.
Aero Estates (T25)
First flight 10/10/2015
375+ hours
Jabiru 3300 Gen 4
Prince P Tip
Taildragger
N1517S
Sonex1517
Postby bvolcko38 » Sun May 17, 2020 9:31 am
I am done using the reamer. Its a bit dull. It looks like someone may have run it backwards, but it still works. I just need an address to ship it to.
Regards and thanks,
BV
Bill Volcko XNS0068
V6
First hole 4/1/16
bvolcko38
Postby OneTallShort » Tue May 19, 2020 11:46 am
Responded via pm with my address. I will also need an address for Gabe if he is still next after myself.
Gregg Short
OneTallShort
Postby N111YX » Tue May 19, 2020 12:07 pm
I'll add that after a few hundred hours of flight time, I began to notice a very small amount of slop/play (1/16th's of an inch) between my dual control sticks with left/right movement. All it took to make them snug again was to tighten the taper pin nuts very slightly and it cinched up the pin to where I'm probably good for another few thousand aileron inputs. Therefore, even the taper pin fit can degrade with use but likely at a rate that is a small fraction of a typical straight bolt. This is something to note for the mixer where play is not to be had.
Kip
Jabiru 3300 #1637 and #3035
Dynon D-180
Becker radios
Garmin GDL 82 ADS-B
1100 hours
48 states visited
Based near Atlanta
Also flying a...
N111YX
Users browsing this forum: WolverineYX and 65 guests
