radfordc wrote:In your installation did you do anything to force cooling air through the top mounted oil cooler? If not, then I can fully understand why your oil temps went up so fast. In the VW auto installation they use a shroud around the cooler and a fan to force air through it. I think in order for the top mounted oil cooler to work you need to install a separate intake and exhaust duct for it.
Also, the top mounted oil cooler isn't a "full flow" system like the bottom mounted oil cooler. Again, this degrades the ability to cool the oil somewhat. Here is a diagram of how the top mounted cooler works: http://www.thesamba.com/vw/forum/viewtopic.php?t=280293
SvingenB wrote:radfordc wrote:In your installation did you do anything to force cooling air through the top mounted oil cooler? If not, then I can fully understand why your oil temps went up so fast. In the VW auto installation they use a shroud around the cooler and a fan to force air through it. I think in order for the top mounted oil cooler to work you need to install a separate intake and exhaust duct for it.
That diagram makes no sense to me. Does the top mounted oil cooler has a thermostat? There is no way the oil will flow like that unless there is a thermostat valve mounted on the oil cooler, but there is none in the drawings, and I didn't believe the top mounted cooler has one.
radfordc wrote:SvingenB wrote:radfordc wrote:In your installation did you do anything to force cooling air through the top mounted oil cooler? If not, then I can fully understand why your oil temps went up so fast. In the VW auto installation they use a shroud around the cooler and a fan to force air through it. I think in order for the top mounted oil cooler to work you need to install a separate intake and exhaust duct for it.
The oil relief valve at the front of the engine controls how much oil goes through the oil cooler. When the oil is cold and thick none of it flows through the oil cooler (it's like trying to pour molasses through a sieve); all of the excess oil not going to the bearings is dumped into the crankcase through the oil relief valve. When the oil is hot it's viscosity is lower and its now able to flow through the oil cooler. As oil begins to flow through the oil cooler the oil relief valve begins to close and less oil is dumped into the crankcase. Note that the top mounted oil cooler is not "full flow" like the bottom mounted cooler. Eventually, the oil relief valve closes completely and all the hot oil is flowing through the oil cooler.
Sonerai13 wrote:Make sure the baffles are properly fitted in the cowl and make sure the cooling outlet at the bottom of the cowl is the proper size (at least 125% of the inlet opening area) and has a "lip" on it to get the airflow right. If the air is flowing properly through the cowl, the cooler will work.
Joe
"Fortes Fortuna Adiuvat"
Users browsing this forum: No registered users and 33 guests
