gyroron wrote:But was weird that in flight there was no power or running issues till I throttled back down to idle.
gyroron wrote:I would have to drill out some rivets to even get a look inside there, that or some type of camera system?
tx_swordguy wrote:Ron, for no other reason than time in service, change the fuel filter. It may have been getting just enough fuel to the carb with the majority of the filter clogged. Vibration could have shifted some sediment to cover up the only part of the filter allowing fuel to get through.
GraemeSmith wrote:tx_swordguy wrote:Ron, for no other reason than time in service, change the fuel filter. It may have been getting just enough fuel to the carb with the majority of the filter clogged. Vibration could have shifted some sediment to cover up the only part of the filter allowing fuel to get through.
What Mark says here and what I said on your FB post where you elaborated that the fuel filter had not been opened since 2016. It's a dirt cheap and simple check to do. And awful expensive one to overlook if a clogged filter is what it is.
Following in a constructive tone - not to start a flame war.... : And as I also said on FB - three Condition Inspections and no one thought to open the filter to examine it? Honestly? That's an accident waiting to happen.
Users browsing this forum: WolverineYX and 75 guests
