by MichaelFarley56 » Thu Oct 03, 2013 8:31 pm
Hey Sam,
Great question! Both the Sonex and the RV-7 have a lot in common. Both are great airplanes with a loyal customer base. Both have excellent flying qualities and are a blast to fly without being challenging or tough to fly. Both are aerobatic capable (if that happens to be your thing).
The advantages to the RV is that it's the faster of the two, and probably generally regarded as the better long distance cross country platform. A lot of people install a 180 or 200 horsepower Lycoming in the RV, giving 170-180 knot cruise speeds. Combine that with the practical ability to build IFR capability into the airplane, and you have a fast, capable sport plane.
The Sonex also has some very good advantages as well. First off, the cost to build and operate is a great deal less with a Sonex. While building a nice RV runs a lot of people $80,000-100,000 a nice Sonex is literally half that. Operating costs are also much less; 180 h.p. RV's seem to burn around 8-10 gallons per hour, while Sonexes once again are literally half of that. Even the 120 h.p. Jabiru 3300 will only burn around 5-5.5 gallons per hour, or less if you're just out having fun. Think of it like this...the Sonex will give you 75-80% of the performance of an RV at only 50% of the cost!
Secondly, building a Sonex is much faster, especially now that Sonex has provided the matched hole construction. You don't need to dimple every rivet hole in the Sonex, and riveting can be done by yourself. This saves a ton of time, maybe even half! I normally hear 1200 hours to build a Sonex, and 2400 hours to build an RV.
Finally, don't forget that the Sonex qualifies as a Light Sport airplane while the RV is not. Hopefully it won't matter, but if you ever have a medical issue this could make a huge difference.
As for the cross country portion of your concerns; I completely understand the dilemma but remember that, even in stock form, 2.5 hour legs in a Sonex really isn't an issue. In my experiences, I'm more than ready to get out and stretch after that much time anyway so the amount of fuel the Sonex carries really isn't an issue. Like Mark said, you and your wife will have tons of flexibility for carrying cargo, fuel, etc.
In the end, I'd say build whatever your heart tells you to build! If 99% of your time is flying long distances, by all means go for the RV. If you're more interested in saving some money while still having a blast flying an airplane you built much faster, than go for the Sonex!
Waiex #0056 - N569KM
Jabiru 3300A #1706
