builderflyer wrote:Yes, wing loading isn't the only factor. Certainly, inertia is very important, too. But if one is only going to consider one factor, wing loading isn't to be ignored when dealing with turbulence or a wind gust when landing.. When I fly my Sonex, alone and with a half tank of gas, my wing loading is only about 9 psf but the good news is that the controls are much more responsive than, say, a Cessna 150. The greater challenge is not overcontrolling when making corrections in response to a gust of wind.
Art,,,,,,,,,,,,,,,,,,,,,,Sonex taildragger #95,,,,,,,,,,,,,,,,,Jabiru 3300 #261
N190YX wrote:In another thread here I read about builders considering changing to castering tailwheels. This may result in what I found to be a very stable configuration to one that may be less stable. Consider the pros and cons of such a change. What are you gaining at the expense of a less stable ground handling airplane?
P51 Pilot Notes wrote:Taxi with stick slightly aft of neutral. This will lock the tail wheel. In the locked position the tail wheel may be turned 6 degrees to the right or left by use of the rudder pedals. For sharp turns, push stick forward of the neutral position to allow the tail wheel full swiveling action.
Users browsing this forum: Google [Bot] and 76 guests
