Paul Johnson wrote:Has anybody tried squeezing the trailing edge of the aileron on the light wing to correct for a heavy wing as they do on Vans Aircraft.
GraemeSmith wrote:When I acquired my plane from the builder and after I started to get her down I determined she was left wing heavy and constantly rolling slightly left. Didn't do it on the test flight with him. I measured the heck out of everything to make sure she was put together OK. And everything checked out. Double checked the right flap and it was good.
Took someone flying and.... she didn't roll left. Was that really it? She was rolling into me sitting left side? REALLY?
I put a small and very thin bit of bungee into the system next to the stick to trim her when I was flying solo to eliminate the roll. Next time I took a passenger - she rolled right into my bungee trim.
So - I've now arranged that the bungee can be easily hooked/unhooked depending on passenger.
Looking out on the wing to see how much "break" this has caused in the trailing edge. It's imperceptible.
But the ball is now easier to keep centered.
Might want to try applying some lateral trim before squeezing an aileron?
YMMV
Users browsing this forum: Bing [Bot] and 25 guests
