by N111YX » Tue May 19, 2020 12:07 pm
I'll add that after a few hundred hours of flight time, I began to notice a very small amount of slop/play (1/16th's of an inch) between my dual control sticks with left/right movement. All it took to make them snug again was to tighten the taper pin nuts very slightly and it cinched up the pin to where I'm probably good for another few thousand aileron inputs. Therefore, even the taper pin fit can degrade with use but likely at a rate that is a small fraction of a typical straight bolt. This is something to note for the mixer where play is not to be had.
Kip
Jabiru 3300 #1637 and #3035
Dynon D-180
Becker radios
Garmin GDL 82 ADS-B
1100 hours
48 states visited
Based near Atlanta
Also flying a...
