Crack found in my Xenos's tail post channel.
Re: Crack found in my Xenos's tail post channel.
Postby Rynoth » Tue Apr 28, 2020 11:43 pm
Fritz wrote:One leg of the "C" channel looks like it's split at the bend.
Indeed, an it's very fortunate that the OP caught this during pre-flight before it got worse, and fortunate for us that he shared it with us. In thinking through the worse case of a crack like this progressing, the side skin would still hold on to the rudder hinge for awhile longer. But eventually, if the hinge became detached, stub-rudder and ground steering authority would be diminished/lost. There still would be some yaw authority in the air though the ruddervators. Possible "flapping in the wind" of a loose stub rudder causing additional damage.
This emphasizes the importance of a good pre-flight inspection.
Postby peter anson » Wed Apr 29, 2020 1:06 am
XenosN42 wrote:Am I the only person that doesn't see a crack in the posted photo?
Wow, I'm with Michael on this. When you mentioned a crack I was looking for a tiny little crack with the potential to grow bigger. I didn't expect the whole flange to be falling off the channel. On the Sonex that channel is folded from 0.032" material with a 1/16" radius. Does it look like the fold was OK?
peter anson
Postby Spaceman » Wed Apr 29, 2020 7:14 pm
Sonex just sent out a required service bulletin for this issue. That was quick!
Chris Paegelow
http://paegelow.blogspot.com/
Spaceman
Postby Sonex Foundation » Wed Apr 29, 2020 8:24 pm
President
Sonex Builders and Pilots Foundation
http://www.Sonexfoundation.com
Sonex Foundation
Postby Rynoth » Wed Apr 29, 2020 8:41 pm
Good on Sonex for jumping on this. I inspected mine today and found that it was difficult/impossible to visually see the actual channel bend without pulling the hinge pin and removing the rudder due to the tail post doubler being in the way.
Users browsing this forum: No registered users and 65 guests
