Rynoth wrote:jerryhain wrote:I’m installing the turbo now and going to change my needle from a 2.5 to 3.0 because from idle to full throttle I’ve always had to enrich the mixture to keep it from dying.
Getting a bit off topic at this point, but when it comes to the 2.5 to 3.0 needle, does it actually change the "curve" of fuel mixture, or just provide more fuel at all power settings? I'm very familiar at this point with needing to lean the mixture at low settings and enrichen at high settings using a 2.5 needle in the turbo, I'm just wondering if the 3.0 needle actually addresses that issue.
jerryhain wrote:Sorry about getting off topic here. in describing this I’m using 100% as cut off and 0% for full rich. At idle I’m at about 90%, and as I move the throttle forward when I get to 1800 rpm I need 75% or it dies. At 2400 RPM I move the mixture to 45 to 50% and then full throttle 3000 RPM and above I have to go to about 25%. The mixture changes aren’t just to make it run better it’s to keep it running at all.
sonex1374 wrote:[New topic split from previous thread - viewtopic.php?f=28&t=5501&start=20#p42001]
Ryan,
In the case of a #3 needle compared to a #2.5, when both needles are installed with identical flow areas, the #3 has a steeper taper, so the needle thickness at low throttle is thicker and results in less fuel flowing at that low throttle setting.
f
builderflyer wrote:sonex1374 wrote:[New topic split from previous thread - http://www.sonexbuilders.net/viewtopic. ... =20#p42001]
Ryan,
f
Hi Jeff,
Take another look at what you said in the above paragraph........."the #3 has a steeper taper".............which is correct but some may be confused by what followed in that it applies to the #2.5 needle, not the #3 needle as it might appear. So for clarification, what it could say is "the #2.5 needle thickness at low throttle is thicker and results in less fuel flowing at that low throttle setting".
I hope I haven't confused this any more,
Art,,,,,,,,,,,,,,,,,,,,,Sonex taildragger #95,,,,,,,,,,,,,,,,,,,Jabiru 3300 #261
Users browsing this forum: WolverineYX and 83 guests
