daleandee wrote:Here is a decent air/oil separator that is reasonably priced:
http://www.aircraftspruce.com/catalog/e ... eather.php
At present I do not use an air oil separator as Myunn isn't putting much oil out the breather yet. When I do need one I suppose this is the one I will use.
FWIW,
Dale
N319WF
mike.smith wrote:Found this for a home-made air/oil separator. I think I'm going to make something like this.
http://www.y8s.com/celica_gone/air-oil/
Sonex #439
kmacht wrote:With the PVC idea and the one above using the paint thinner can, what did you do to keep the chore boy pieces from draining back into the valve cover? Do you have some sort of screen or way to keep the pieces that will eventually fall off from flowing back with the rest of the oil? I seem to remember a few years back where a few people were putting the chore boy scrubbies in the hole just under the plate for the breather hose eliminating the need for an air/oil seperator. Sonex strongly recomended against it since small pieces of the chore boy could fall back into the engine .
Users browsing this forum: No registered users and 36 guests
