Bacon8tor wrote:I saw your post about your fuel valve placement on the tank and not going with the revision from Sonex. After seeing that I did the exact same thing.
Bacon8tor wrote:From two sources I’ve been told the 2nd ignition shouldn’t be turned on for more than 15 seconds to a minute without the engine running.
gammaxy wrote:Bacon8tor wrote:
Interestingly, I've noticed that after ~2 seconds of no engine spinning, the triggers on my Aerovee stop providing power to the coils. So, at least as long as the engine isn't running, the secondary ignition isn't drawing any current..
Rynoth wrote:This has always been my impression as well, that the Aerovee secondary coil draw is RPM dependent, i.e. how often it's actually firing.
I recently finished the electrical system and didn’t have this problem before. I could have the master and 2nd (electronic) ignition on all day with no problems.
sonex1374 wrote:Kinda improbable that is works out like this, but once or twice in a blue moon the stars will randomly align.
Users browsing this forum: Google [Bot] and 65 guests
