Cotton Waiex 191 - N191YX
Re: Cotton Waiex 191 - N191YX
Postby Bryan Cotton » Wed Sep 18, 2013 10:09 pm
I assembled the left hand side with similar results. This time I was careful to take the springback out of the flanges, so the bottoms were 90 and the tops matched the angle of the front spar in the plans. I did not think that would make a difference for a dry fit, as on the right side the clecoes were able to pull everything in without difficulty. I checked the straightness of the aft spar and the forward spar (with the hockey stick removed for convenience) and they were good. Any ideas? I have the question into Sonex tech support.
Both stabs
Postby Bryan Cotton » Fri Sep 20, 2013 9:45 am
Skins....
Postby Bryan Cotton » Sat Sep 21, 2013 5:32 pm
First rivets!
Postby Bryan Cotton » Sun Sep 22, 2013 6:44 pm
My forward spars for my stabilizers are riveted.
Hockey stick riveted, rib clips bolted
Postby Bryan Cotton » Fri Sep 27, 2013 8:54 am
Ok, I found that WIX-T11-09 rib was the culprit. It was too long, both parts. I am going to hack off the angled tab and rivet on another to make the proper spacing. Lesson learned: if things don't fit measure all the parts and compare to the plans.
Only -09 is wrong
Postby Bryan Cotton » Sat Oct 12, 2013 6:49 pm
We riveted together the right hand tail skeleton. I used AN426 4-4's as I had a regular #30 dimple die I was willing to grind down. These are Adam's first bucked rivets.
Done!
Bucking rivets
Postby Bryan Cotton » Wed Oct 23, 2013 11:36 pm
We finished riveting the skeletons together. I drilled on the hinges tonight. I made a little tool to help with the drilling - a piece of furring strip with a groove to clear the hinge.
Deleted photos for quota
Holes drilled and clecoed
Postby Bryan Cotton » Thu Oct 24, 2013 11:14 pm
Skins clecoed. Need to bring the bottoms all up to #30, Adam and I did the tops earlier.
Postby Bryan Cotton » Sat Oct 26, 2013 5:26 pm
The joy of deburring- it is better when shared.
Postby Bryan Cotton » Sun Oct 27, 2013 6:06 pm
We are mostly deburred. Tried polishing for the first time.
12 year old automatic polishing machine
Hey... it works
Return to Photo Album
