tires
Re: tires
Postby sonex1374 » Fri Mar 13, 2020 11:22 am
Bill,
I also replaced the wheel hardware (bolts and nuts) joining the wheel halves together. This was mostly because I mounted Great Plains (now O'Keefe) hydraulic brakes, and mounting the "top hats" and brake discs required longer bolts. I used standard AN5 bolts and locknuts. Standard AN hardware also makes it easy to replace locknuts as they start to get worn from a few on-off cycles replacing tires.
Jeff
Jeff Shultz
Sonex TD, 3300, AeroInjector
Kansas City, MO
http://www.sonex604.com
sonex1374
Re: tires
Postby N111YX » Sat Mar 14, 2020 10:09 am
As stated before in posts from years back, changing the Azusa bolts to AN5 is a good idea. I have personally seen a broken bolt from the inside of a Azusa wheel from a Sonex. Thus, two (inferior) bolts were left with carrying an even greater load. I suspect that an AN5 bolt has a better quality control history than an Azusa bolt. It's cheap insurance in my opinion.
Kip
Jabiru 3300 #1637 and #3035
Dynon D-180
Becker radios
Garmin GDL 82 ADS-B
1175 hours
48 states visited
Based near Atlanta
Also flying a...
N111YX
Re: tires
Postby bvolcko38 » Mon Mar 16, 2020 9:40 am
Do you recall what size AN5 bolt is used? I don't want to disassemble my wheels again to measure the grip.
Bill Volcko XNS0068
Aerovee and Prince P-Tip
V6
First hole 4/1/16
First flight 8/24/18
Phase I complete...finally!!!
bvolcko38
Re: tires
Postby jowens » Mon Mar 16, 2020 3:17 pm
Does anyone have experience with http://www.okeefeaero.com SLICK 12x4x5 tires?
Jim Owens
jowens
Re: tires
Postby kmwoody » Tue Mar 17, 2020 12:14 pm
I have had them for years and they last forever. They split the difference, in height, between the stock tires and 5x5.00. It's been awhile but i think they are 2 lb per side heavier than stock. I damaged one, cut it open, and they have about an 1 1/2" tread on the corners. My Sonex wears tires on the inside. Easy to see wear marks. Again, they last forever.
Ken W
Sonex 959
Camit 3300
kmwoody
Re: tires
Postby jowens » Tue Mar 17, 2020 10:22 pm
Thank you, Ken!!
Jim Owens
jowens
Return to Sonex-B / Waiex-B
