adoepner wrote:In case that I discover it can, I am having the plug to the main oil galley of my case drilled and tapped for a pipe plug. This will allow me to return oil there, instead of at the pump, and change my pump cover to one with a built-in pressure relief (example http://www.geneberg.com/product_info.ph ... cts_id=320).
adoepner wrote:1) I would like to know what size the "stock" oil pump is that ships from Sonex. I think this is just a measure of the diameter of a gear in the pump (21mm or 26mm or 30mm, etc.) - someone please correct me if I am mistaken.
rizzz wrote:adoepner wrote:In case that I discover it can, I am having the plug to the main oil galley of my case drilled and tapped for a pipe plug. This will allow me to return oil there, instead of at the pump, and change my pump cover to one with a built-in pressure relief (example http://www.geneberg.com/product_info.ph ... cts_id=320).
That's what I have on mine:
http://www.vwaircraftengines.com/viewto ... ?f=20&t=58
haven't chosen a suitable oil cooler/filter yet though.
mike.smith wrote:rizzz wrote:adoepner wrote:In case that I discover it can, I am having the plug to the main oil galley of my case drilled and tapped for a pipe plug. This will allow me to return oil there, instead of at the pump, and change my pump cover to one with a built-in pressure relief (example http://www.geneberg.com/product_info.ph ... cts_id=320).
Where are the pushrod tubes? I saw the pushrods in the photos, but no tubes running from the engine to the head.
