gammaxy wrote:I've measured the steady state current of the starter contactor at 6 amps. I believe there's also a very substantial inrush current before the contactor fully engages that might be triple or more this steady state current.
sonex1374 wrote:
The 14g wire to the starter only activates the starter solenoid, and should not have anywhere near 30 amps flowing through it (should only be 2-3 amps max). You might have that wire connected to the wrong terminal (e.g. the fat terminal that provides starting current to the starter), or there may be a wiring problem internally. I suggest looking these connections over and see if anything becomes apparent.
Rynoth wrote:You had the starter circuit open while engaging the starter solenoid? Makes me wonder if the solenoid circuit might draw more amps for some reason if the starter doesn't actually have its own power.
