by Bryan Cotton » Sat Feb 01, 2020 11:55 am
Made #2.
I drilled a hole 7" down from the top and put a grommet in it.
To get the wires routed, I used a stiff piece of wire like you use to hang a suspended ceiling. Pushed it through the grommet and out the top. Bent the tip around one of the conductors from the 24ga pair and pulled it through. The first attempt pulled the grommet out. Then I made a tool to help the wire turn the corner. I cut the groove with a Dremel. It sits on top of the grommet.
One side done. There will be a service loop on the 45 degree angled part of the stick mount. I've ordered some Deans connectors for the junction here. I've also left some extra wire if needed for maintenance.
