Any ideas on Ways to jump start engine with cowl on?
Re: Any ideas on Ways to jump start engine with cowl on?
Postby GraemeSmith » Fri Jan 17, 2020 11:10 am
sonex892. wrote:I mounted an Anderson plug to the gear leg bracket its flush with the bottom of the cowl. Its mainly used as a charging port but I have used it as a jump starter on a couple of occasions. Sorry its not a great photo of the bracket itself, the bracket is made from left over 6061 angle
Charging - yes - I'm about to fit one of those in the side of the cowl so a solar panel will maintain the battery in the tie downs.
But a starting current over those thin wires?......
Look at the weight of cable you would fit to an External Receptacle like this one on Spruce - more like the gauge you use from the battery through contactor to the starter:
https://www.aircraftspruce.com/catalog/ ... errect.php
Graeme JW Smith
GraemeSmith
Postby sonex892. » Fri Jan 17, 2020 7:28 pm
Yes those cables in the photo are smaller than the recommended battery to starter sizes. Disclaimer, I'm not recommending sizes for anyone here just saying what I used. But I think from memory I used 8 gauge (10mm2) to the Anderson plug. Main starter wire is 4 gauge (25mm2).
Unless the primary aircraft battery is totally cactus or dead flat or it wasn't starting due to a bad connection, the aux cable would not be carrying anywhere near the full starting current. Also in my opinion, if the battery was totally dead it would be a very stupid idea to attempt a jump start and go flying regardless.
Steve
Lazair kit 1981 sold
Sonex kit 2010
Sonerai 2LS project rotax 912
sonex892.
Users browsing this forum: No registered users and 160 guests
