gyroron wrote:My plane is very sensitive about its starting procedure. On a cold engine, first start of the day, you got maybe 20-30 seconds worth of cranking before the battery is too weak to turn the engine over fast enough to ever start. ( Jabiru 3300 )
I probably should have a larger battery in it, it currently has a Odyssey 625 in it, brand new matter of fact, But a bigger battery would require a new box, and would add more weight so I would like to keep the smallish 625.
Too many times since I bought this plane I have had to use jumper cables to the car to get it going. I could live with that if I could easily access the battery, but pulling the cowl is a PITA.
Wondering if anyone has figured out a practical easy way to jump start one without pulling the cowl.
One idea a buddy gave me was to buy something like this, and extend the leads long enough to pass through the firewall into the cockpit, install the ends of the leads with eyelet type connectors to the battery, then if needed, can just access the other end of the cord in the cockpit, plug in the booster box and jump it off and then disconnect once running and stow it in the luggage area or leave in the hangar. Your thoughts?
https://www.amazon.com/dp/B07MJBDD5K/re ... HJ1ZQ&th=1
Email it to me if you could. my email is sawad13@msn.comMsing48 wrote:Here are a couple of photos of the jump start post on a Sonex. The post is insulated from the airframe and extends through a hole in the cowling. The cable goes directly to the battery + terminal. I have one to mount on my plane but the brass post diameter has been reduced.
Now I can’t get the photos to attach. Suggestions?
Users browsing this forum: Google [Bot] and 28 guests
