dirkverdonck wrote:Hi Wes,
Had the same issue a while ago and solved it before skinning! see pics.
Enjoy the build and a Happy New Year,
lgsievila wrote:Hi Wes,
The interference problem has been around since the beginning. I posted a picture of the drawing on Mykitlog website on 04/17/2012 where I showed material that had to be removed for push rod clearance.
"I pulled out the swivel set screws and they were all rusted. I was able to get the ball in two of the screws to rotate but the other two were hopeless. Probably best to just get new ones. I'll check with the factory Monday to see what the situation is. Meanwhile I googled a little and came up with these: https://www.nbk1560.com/en-US/products/ ... CSS-R(INCH)/. They are available in steel and stainless. Haven't checked delivery."
WesRagle wrote:I found my factory swivel set screws were a little short. As an alternate source for you, after a lot of searching on the internet I found "ball ended thrust screws" on MSC Industrial Supply. For what it's worth.
thomasjones42 wrote:Wes,
MSC part number is 74698515. Thread is 5/16-18. Overall length is 1" 9/16". Thread length is 1" 1/4".
Tom Jones
Onex 0133
Turbo Aerovee
