Bryan Cotton wrote:I put my tips on with nutplates. I was going to use aluminum rivets on the left one....
Spaceman wrote:I'm contemplating this same issue now. Has anyone considered just inserting the piano hinge pin from the bottom? There's nothing to block it, and you could secure the pin by safety wiring it or using a tiny cotter pin like the aileron hinge pin.
I just put the pin in backwards and there's nothing in the way, and it seems like you could just replace the top two bolts on the tail post with drilled head bolts, then you'd have a perfect thing to safety wire the pin to.
Any reason not to do this? I can't imagine there's any risk of the pin coming out if it's properly safety wired, and that would make the ruddervators easily removable without messing with the stabilator tips.
Attached is a picture of what I'm talking about.
