Cotton Waiex 191 - N191YX
Re: Cotton Waiex 191 - N191YX
Postby Bryan Cotton » Sat Aug 24, 2019 12:24 pm
Working oil cooler baffle.
I've lost my co-builder to college.
Postby Bryan Cotton » Sun Aug 25, 2019 2:18 pm
This side is done. I have to figure out the hose routing next.
Postby Bryan Cotton » Sat Sep 07, 2019 11:56 am
I couldn't get the hoses to work. I made more ducting.
This part has been a pain. I've named it Bryan's Bane.
I did finish the exhaust mount.
Postby Bryan Cotton » Sat Sep 07, 2019 8:39 pm
Adam came home this weekend. He finished sanding the bondo and started squirting paint.
Progress on Bryan's Bane.
I used AN470AD3 solid rivets where I could, flush 3/32" pops where I couldn't.
Postby Bryan Cotton » Sat Sep 21, 2019 12:58 pm
Bryan's Bane will be the death of me. I've given up on that approach and am taking a break.
Meanwhile, I've started mounting my nav lights. I have a nifty set of 3D printed mounts courtesy of Kevin H. I think he has the design posted on thingverse. They are for Whelen Orion 600s. Here nutplates have been added and one baseplate screwed on.
Light mounted:
I used the spar wingtip mount rivet line as my vertical reference. They are slid down far enough that I can't see them, but they are not masked by the wingtip when directly above.
I am considering cutting out the outboard tip ribs between the lightening holes, like we do for flap access. That will let me get access to my molex connector through the landing light hole. This way I can depin the connector if I need to remove the light. I have a piece of 1/2" OD poly tubing from the behind the mount through the spar tip to route the wires.
Postby GordonTurner » Sat Sep 21, 2019 5:19 pm
Is your wiring routed aft of the spar?
Postby Bryan Cotton » Sat Sep 21, 2019 8:27 pm
Nope, forward of the spar.
Postby Bryan Cotton » Sat Oct 05, 2019 10:48 am
The mounts are JB welded and riveted on. A little bondo for filleting.
Postby Bryan Cotton » Tue Oct 08, 2019 12:08 am
Paint
The wheelpants had some runs, pinholes, and uneven coverage. I ground out the pinholes, filled them with 5 minute epoxy, and wet sanded them.
Messy.
Postby Bryan Cotton » Thu Oct 10, 2019 12:25 am
Wing walk:
Installing wingtip. I put the the molex connector on and mated them before I closed it up.
Buttoned up. I'll test the harnessing out before I rivet anything.
Wheel pants take 2. Probably good enough.
Return to Photo Album
Users browsing this forum: autopro and 15 guests
