I wanted to post a quick update on the rebuild of AeroVee #0631. Yesterday morning, I was finally able to take my Waiex up for a 45 minute test flight to check the rebuild and new systems installed on the airplane.
First off, as you all know I modified the setup to include a top mounted oil cooler, just like the Onex setup. This required a new oil pump that does not have the threaded external ports, as well as the needed hardware to mount the oil cooler on top of the block. I also fabricated a box to force air through the cooler and out the back of the rear baffling piece:
![Image](http://img.photobucket.com/albums/v687/MikePGT/image_zps0c2beaf6.jpg)
Anyway, after a few quick ground runs, it was time to take the Waiex up and see how the oil pressure was after rebuild. Thankfully, everything seemed to be a complete success with the engine not only running better (I switched back to 8 to 1 compression), but the oil pressure was excellent:
![Image](http://img.photobucket.com/albums/v687/MikePGT/image_zps7fbfc050.jpg)
I know it's tough to see but my mechanical gauge was showing pressure between 56-58 PSI, while my digital gauge was right around 60 PSI. I'm thrilled that everything worked!
I know some people were asking about my oil temps with the top mounted cooler, and to provide some feedback I did notice that they ran higher than the older bottom mounted system. Everything was certainly still fine as I didn't see oil temps get over 190 (80 degrees outside) and most of the time they hovered around 180. This was while running the engine hard so I'm sure everything is good in that regard, so if anyone wants to know if I recommend the top mounted cooler, at this point it seems to work just fine. It's a tight fit inside the cowling but I do think it will make things much easier when it's time to change the oil.
I'll continue to offer reports as I keep flying the Waiex. Thanks everyone!
