2nd ign tach not working
Postby Johns » Tue Sep 03, 2019 3:30 pm
While trouble shooting this problem I was wondering if the 2nd ign tach is needed for the annual condition inspection.
FAR 91.205, paragraph 2, #4, reads "tachometer for each engine". #1 ign tach works just fine and engine runs fine on ign 2 but without the tach.
What do ya think? John
Johns
Re: 2nd ign tach not working
Postby XenosN42 » Tue Sep 03, 2019 7:56 pm
What?
-- Michael
OneX N169XE
XenosN42
Postby tx_swordguy » Tue Sep 03, 2019 8:25 pm
not being an a&p I would interpret that to mean you have one engine so as long as you have one tach it is legal. Unless you bring it to the a&p attention and he wants to be super picky about it, I would not worry about it. It would be nice to have for your "mag drop" test on run up, but as long as the kill switch works and all other aspects of it work I don't think I would be worried about it for your condition. I would want to have it fixed for my own knowledge however.
Mark
Mark Whiddon
T25 Aero Estates
Sonex N889AP
jabiru 3300 solid lifter
tx_swordguy
Postby Sonerai13 » Wed Sep 04, 2019 9:59 am
One tachometer per engine (not per ignition system) is fine. There's no reason to have a separate tachometer on each ignition system. On the AeroVee we usually took the tach reading off the alternator rather than either ignition system.
Joe Norris
Sonex N208GD (S/N 450)
Sonerai II N13NN (S/N 1206)
Fortes Fortuna Adiuvat
Sonerai13
Postby GordonTurner » Wed Sep 04, 2019 10:18 am
In any case, 91.205 typically doesn’t apply to EAB anyway unless you are flying at night or IFR.
Postby Johns » Wed Sep 04, 2019 3:50 pm
Thanks everyone! And yes, I will be working on getting the second tach working!
John
Johns
Postby Scott Todd » Wed Sep 04, 2019 5:49 pm
It still seems like over complication unless you just want to see how much stuff you can get on your panel. Like Joe said, why not just hook it to the Regulator like suggested in the Manual?
Scott Todd
Users browsing this forum: Google [Bot] and 90 guests
