Exhaust Heat Containment
Postby WesRagle » Mon Aug 12, 2019 4:48 pm
Guys,
I'm at the point I need to decide exactly how I want to handle exhaust heat in the engine compartment. I want to either coat or wrap the pipes. The question is which way to go. I just got a quote from Jet Hot for their "top of the line" coating and quite frankly I'm choking on it (~$500). $283 for classic polish.
That leads me to consider wrapping the pipes. Some folks claim that wrapping exhaust headers is a bad idea and will destroy them. Maybe corrosion is more of an issue with mild steel. Don't know.
Question: Has anyone running header wrap on their pipes had any issues with corrosion?
Wes
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Hummel 2400 w/Zenith Carb
Prince P Tip 54x50
First Flight 06/23/2020
42.8 Hrs. as of 10/30/21
WesRagle
Re: Exhaust Heat Containment
Postby GraemeSmith » Mon Aug 12, 2019 6:27 pm
Can tell you that on the new to me Sonex - the exhaust pipes are wrapped. Generic shot of under the cowl - you can see what I mean. I'm still trying to get more heat out from under the cowl.
No idea yet about the corrosion issues.
Graeme JW Smith
GraemeSmith
Postby WesRagle » Mon Aug 12, 2019 6:55 pm
Yea, the more waste heat that can be contained and disposed of the better.
So, while talking to the Jet Hot sales person I mentioned coating AND wrapping the pipes. Of course the answer I got was that only their most expensive coating was approved for wrapping, However, she also said that if their coating failed (which is ill defined) they will provide an upgrade for the cost difference. Also, the left pipe can't be coated on the inside due to my needing a heat muff for carb heat. That will diminish the effectiveness of the coating.
We'll See,
Wes
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Prince P Tip 54x50
WesRagle
Postby Bryan Cotton » Mon Aug 12, 2019 6:57 pm
We just wrapped our pipes. I bought them used and they were wrapped before. I see no signs of corrosion.
Postby WesRagle » Mon Aug 12, 2019 7:00 pm
Bryan Cotton wrote:We just wrapped our pipes. I bought them used and they were wrapped before. I see no signs of corrosion.
HI Bryan,
How many hours on the pipes?
Wes
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Prince P Tip 54x50
WesRagle
Postby MichaelFarley56 » Mon Aug 12, 2019 7:24 pm
HI Bryan,
Wes
I sold Bryan my exhaust when I installed the turbo and, at the time, I had been running those pipes around 2.5 years and 150ish hours, wrapped the whole time. No issues at all.
After I pulled the turbo I put a new set on, and have been running those wrapped for nearly 3 years and another 150 hours. No issues.
These are good quality pipes and we really don’t run them that hot. From my experience, I’ve seen no issues.
Waiex #0056 - N569KM
Jabiru 3300A #1706
Postby mike.smith » Mon Aug 12, 2019 7:49 pm
WesRagle wrote:Guys,
Wes
Been running header wrap for over 5 years and 400 flight hours. Not a spec of corrosion, even being tied down outside for 5 years.
Postby fastj22 » Mon Aug 12, 2019 10:25 pm
My stainless headers have been wrapped for 400 + hours, no issue. My new b model will have mild steel wrapped tail pipes below the headers. I just can’t see how they would be more susceptible to corrosion. We’ll see.
Postby WesRagle » Tue Aug 13, 2019 12:05 pm
Thanks guys. I think I'll go with the wrap.
Wes
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Prince P Tip 54x50
WesRagle
Postby bvolcko38 » Tue Aug 13, 2019 12:08 pm
I have been having heat related issues with my Aeroinjector. I put additional thermocouples to investigate temps. One at the carb throat one at the gascolator outlet and one just outside air cleaner. I had already installed a blast tube to the gascolator.
The heat wrap did nothing to help.
My CHTs and EGTs were nominal. Gascolator 90f, carb throat 150f and cowl air temp 120f..... gas was boiling in the carb.
I put a NACA submerged inlet in the bottom of the cowling 3" in front of the air cleaner. Problems solved!!!!
Bill Volcko XNS0068
Aerovee and Prince P-Tip
V6
First hole 4/1/16
First flight 8/24/18
Phase I complete...finally!!!
bvolcko38
Users browsing this forum: No registered users and 68 guests
