6.00x6
6.00x6
Postby bvolcko38 » Tue Jun 04, 2019 1:32 pm
Will 6.00x6 tires fit inside standard Sonex wheel pants? I’m thinking of upgrading to real aircraft tubes and tires. I’ve got 5” now that came with the kit. I fly mostly off grass. I’m sure 6” is better than 5” in that regard
Bill Volcko XNS0068
Aerovee and Prince P-Tip
V6
First hole 4/1/16
First flight 8/24/18
Phase I complete...finally!!!
bvolcko38
Re: 6.00x6
Postby Jerry09w » Tue Jun 04, 2019 10:43 pm
I have been running aircraft 500x5's on all 3 wheels using original Sonex wheels, The main gear wheel covers worked. I just put on some 15x600x6 tires on the mains and they do not fit in my Sonex wheel pants.
Jerry
Jerry09w
Re: 6.00x6
Postby GordonTurner » Tue Jun 04, 2019 11:29 pm
Hi Jerry
Like the way your heading!!!!
Any chance of a Pirep on the old and new tires?
Thanks, Gordon
GordonTurner
Re: 6.00x6
Postby sonex892. » Wed Jun 05, 2019 4:30 am
Mcreary Airhawks 5.00 x 5 are what I use. They are a couple of inches bigger in diameter than what comes with the Sonex. They only just fit in the Sonex wheel pants.
Steve
Lazair kit 1981 sold
Sonex kit 2010
Sonerai 2LS project rotax 912
sonex892.
Re: 6.00x6
Postby Gordon » Wed Jun 05, 2019 8:29 am
Larger Tires...……?
Hey Bill...….I installed 5:00x5 Airhawks on the stock wheels on my Onex.
They are a couple inches higher than the stock tires and just barely fit inside the wheel pant however no mods were needed.
I really doubt that you could use 6:00x6 tires and wheels without doing some fiberglass work.
I also have the Sonex 6" tail wheel...….makes for a good combination.
Gordon...….Hummel 2400.....Onex
Gordon
Re: 6.00x6
Postby Darick » Wed Jun 05, 2019 11:06 am
I'm using the slightly larger tire also. It is a no tread "slick" tire seen often in racing and just fits inside the stock wheel pants. I fly off of grass and a larger tire would be nice. I really dislike working with fiberglass so if someone comes up with a ready-to-use wheel pant I'd consider buying a set.
Darick Gundy
Sonex #1646
N417DG
First flight! 10/21/2017
Darick
Re: 6.00x6
Postby bvolcko38 » Wed Jun 05, 2019 3:19 pm
Thanks for the replies. Answers my question....I guess I will be going the 5.00x5 route. Any one brand better than another? I know, you get what you pay for.
Bill Volcko XNS0068
V6
First hole 4/1/16
bvolcko38
Re: 6.00x6
Postby N190YX » Thu Jun 06, 2019 10:57 am
I use Desser retreads on my factory built airplane. Aviation Consumer's recommended tires. No financial interest.
N190YX
Re: 6.00x6
Postby N418SX » Thu Jun 13, 2019 12:27 pm
Will the 6.00 x 6 tires fit the stock wheels? Is there a better wheel to use? I'm looking at 6.00 x 6 tires to go with my Condor 2 tail wheel. The wheel pants are easily solved andd I'm not worried about fiberglass.
IHN,
Robby Knox
rwknoxjr1959@gmail.com
Hazlehurst, GA
KAZE-Hangar 18
912-429-5761
N418XS Reserved
N418SX
Users browsing this forum: No registered users and 75 guests
