Hi Guys,
Thanks David, got the tools today. Oops fittings should arrive Wednesday (I think).
While waiting on the bits to come together to install the oops fittings I have been working on the nose of the airplane. While fitting the cowl I made about 10 million sharpie marks. Per usual, I used alcohol to remove the marks. I got some alcohol on the inside of the cowl and it instantly got sticky. I didn't expect such a mild solvent to have that effect.
Being what it is, the cowl needs to be a bit more resistant to solvents, oil, fuel, etc.
Questions:
1) I have West Systems epoxy on hand. Is West Systems compatible with whatever the cowl is made of? That is, can I seal the inside of the cowl with a coat of West Systems epoxy?
2) What did you guys use to trim the Lexan windshield?
![Image](https://i.postimg.cc/fyx5P1P6/P1020316.jpg)
Thanks for Your Time.
