sonex1374 wrote: You'll need to remove the rocker arm assembly to gain access to the 4 nuts underneath the rocker arm shaft, so don't skip this step.
sonex1374 wrote: There is no need to loosen any head stud nuts during the re-torque - simply snug up each nut in sequence to the recommended value (18 ft-lbs).
mike.smith wrote:sonex1374 wrote: You'll need to remove the rocker arm assembly to gain access to the 4 nuts underneath the rocker arm shaft, so don't skip this step.
Joe Norris posted something at one time about an offset tool he made to get around the rocker arms to get to those 4 nuts, so you don't have to remove the rocker arm shaft.
Users browsing this forum: No registered users and 81 guests
