142YX wrote:Now for the other problem i ran into. The ruder-vator push rods bottomed out by the spherical rod-ends hitting against their upper safety washer before the assembly moved all the way to the aft stop. Sorry about the bad photo.. it was very hard to get a picture of this:
You can see here more clearly what is bottoming out. In this photo, i have two standard washers above the spherical bearing and it still bottomed out (the prints call for only one). It took THREE washers above the spherical to get all the way to the aft stop, and i find this to be somewhat ridiculous.
Waiex builders, did you have this problem? what did you do?
Users browsing this forum: No registered users and 74 guests
