Cess32cw wrote:Am finally getting to the end of my conversion from a turbo aerovee to a new CAMit3300 with a Bing. Since I have a manifold pressure sender I figured I might as well hook it up on the new engine. Any thoughts on where I should tap into the induction system to obtain the most accurate reading? I am running a HACman and figured I would plumb into it, where it taps in at the carb/air filter but the reading that I am seeing is way high (46 plus inches). Am I better off plumbing into the intake tube at one of the cylinders?
