tx_swordguy wrote:Thanks John, it is not quite as high wattage rated as the EZ HEAT, but it is less than 1/2 as much! Just ordered one. Did you place it on the side of the oil pan or the rear, in front of the intake plenum?
Mark
tx_swordguy wrote:John,
I got the heater you mentioned. I noticed the sump has a rough texture from the casting. Do I need to sand it down smoother? or just make sure it is clean and seal the edge with silicone?
Mark
Users browsing this forum: Google [Bot] and 19 guests
