I'm using the Jegs in line fuel filter, same as other folks are using.
https://www.jegs.com/i/JEGS/555/15034/10002/-1I have the above filter on my AeroVee.
After reading the article "Top Three Fuel System Problem" in January 2019 Sport Aviation, I again looked at my Jegs Fuel filter. It has a 30-40 micron filter inside...40 microns = .0016! I changed out the filter at 5 hours, washed, put away for the next planned inspection, then replaced with the extra one sent from Jegs.
I just inspected the first one I had washed, with a magnifying glass and immediately saw an accumulation of dust, very fine particles in the folds of the filter, missed with the naked eye! This "dust" had to be removed with very pointy tweezers.
My question is...is that fine filter really necessary? I don't think there is any oriface in the AeroInjector that would get clogged with anything that small. On the contrary, it seems there would be more of a danger of the filter getting clogged with something that would otherwise pass through the AeroInjector.
I'm debating if I want to remove the filter and just rely on the finger strainer in the fuel tank. Anybody have any thoughts on this?
