by n502pd » Tue Feb 05, 2019 7:57 pm
Just wondering out loud...sorta...about anyone who has installed a regular, spring coupled, full castering tailwheel assembly instead of the Sonex direct drive design? I was signed off as conventional gear pilot, but still feel that I am just a second class one because of the direct drive Sonex, which is the only TW aircraft I have ever flown. i an most definately not disappointed with the design, but this spring I will be transitioning to hard surface operations. Some have replaced the hard rubber wheel with a pnumatic one, after indicating the hard rubber one tends to skip sideways much easier than the pneumatic tire. this sort of makes me concerned prior to my first hard surface event. And then there is the full castering TW modification, but I am not sure I want to do that just yet, if ever.
Does anyone have experience with the pnumatic tire, and/or the full castering TW mod? That you would want to tell about, maybe!!?
As always, thanks in advance!
Joe Nelsen
scratch built :D
Flying @78.2
KGYI/N. Tx Reg/Perrin Field
