MichaelFarley56 wrote:If you were to guess, do you think it’s an airflow issue through the system or simply a lack of sufficient heat being generated? I’d like to think that, even on our smaller aerovees, there’s sufficient heat from the exhaust pipes to give some cabin heat!
Do you have any pictures of your setup, such as where you installed the divider box on the firewall and how you ran SCAT hoses?
Don’t give up; I’ve been talking to a Hummelbird H5 owner in northern Michigan and he gets great cabin heat from a VW engine the same size as ours. His claim is there needs to be proper airflow exiting the cabin which will draw air through the heating system. An interesting theory at least!
