sport65 wrote:Thanks fastj22. I know its not a heat issue for me though, it will do it on 50 degree days right after start up. Do you use the NGK D9EA spark plugs? I've been told by a aerovee owner he solved this issue with resistive spark plugs. We are just not given this option by Jabiru.
By your first flight I assume your Jabiru is the three wire alternator I have seen in wiring diagrams. Mine is the two wire newer (2015) alternator that is suppose to charge at lower RPM. Maybe its the new alternator that is the issue then that the v6 cant handle some sort of electric noise from it. Anyone have the newer alternator engine with the v6?
sport65 wrote:The regulator I tried happened to have been Kubota. I looked up the iridium plugs and they are resistive. Yes, I used a car Battery outside the airplane with only the radio hooked up to it and it worked fine with the engine running.
I have also tried three different headsets to no avail. No problem with the yellow wire, suggestions are greatly appreciated. Nice score on the Garmin radios, If I replace mine I would want a 2 1/4" replacement so as to not leave a hole in my dash.
