Spaceman wrote:I just installed the Southco fanstener for my fuel filler door, and I aligned the receptacle left-to-right because the front edge of the windshield blocked it from aligning front-to-back. I forgot that now with the receptacle sideways the wing head stud is perpendicular to the airstream with the door latched...
Do they make studs that are oriented 90° off when closed? I haven't been able to find any. If not I guess I'll have to drill out the receptacle and file a little notch in the front edge of the windshield so I can oriented it the correct way!
T41pilot wrote:Spaceman wrote:I just installed the Southco fanstener for my fuel filler door, and I aligned the receptacle left-to-right because the front edge of the windshield blocked it from aligning front-to-back. I forgot that now with the receptacle sideways the wing head stud is perpendicular to the airstream with the door latched...
I had the same issue. Until now, it didn't occur to me about the alignment of the wing nut with the airstream. I guess I'll be changing out the wingnut for something else myself. part# 82-11-100-16 looks like it might work.
Users browsing this forum: No registered users and 95 guests
