SP1 wrote:...used a torch to heat up the piece before bending. Did a similar thing to get the bend in the elevator spar. I take that technique is a no-no, because of loss of temper? Thanks!
Rynoth wrote:SP1 wrote:...used a torch to heat up the piece before bending. Did a similar thing to get the bend in the elevator spar. I take that technique is a no-no, because of loss of temper? Thanks!
Absolutely should not do this for anything structural as it weakens the material strength substantially. The only time that might be OK is when it's non-structural/cosmetic parts like fairings. I shudder at the thought of a spar being heated for bending in this manner. The fuselage sides are definitely structural as well.
Users browsing this forum: Bing [Bot], Google [Bot] and 41 guests
