by Bryan Cotton » Sun Dec 18, 2022 12:36 pm
Congratulations Peter! That is awesome.
I am still working through left rolling tendency. I have center controls so I can switch back and forth. Objectionable forces in the left seat, and perfect in the right seat on my early flying. I've been adjusting the left flap down, as the right flap was up tight. So far I had 1 turn down on the ball joint, and after the last flight I added two more turns. I verified thread engagement. Before I had been going 1/2 turn at a time and currently I have a very slight right roll in the right seat and and noticeably more left roll in the left seat. When I fly today I'll see if 2 turns is too much, not enough, or just right. I have not noticed any performance difference with the adjustments so far.
Shimmy on landing - yep. I'm getting better at avoiding it. Here are my three techniques:
1) For a full stall landing, plant the tailwheel first and do a real stick back full stall drop on the mains. This gets the speed slow and I think more importantly gets weight on the mains. Works best on grass because it's really hard to see over the nose to keep it straight and grass is more forgiving. But, I do it on hardtop too and I'm getting better at judging it.
2) Wheel landings - go from a gentle touchdown to a level attitude with a confident application of forward stick. You see better to keep it straight. Once the main gear is loaded with the weight of the aircraft, it tends not to shimmy.
3) Brakes - I still get a little shimmy, sometimes on the transition to nose high or in the aftermath of a full stall landing on hardtop. Once I am settled and stable, a little application of brakes generally shuts down the shimmy.
Oddly, I've never had high CHTs. Not sure if my TCs are bad or if I've just done an awesome job with my baffling. I really did go pretty nuts on the baffling.
Your Sonex B looks great!
