Thanks for the info on the CHTs. How do you like your performance?wlarson861 wrote:The generation 4 engines have hydraulic lifters and the new cast case and cylinders. Several outside dimensions have changed but it still fits the old mount. As for cylinder temps the hottest I have seen are around 335. But the cht on the efis are all very equal. I would say 5&6 are probably the warmest which would be the value above. On a high altitude test flight (9000 + feet) OAT was 65 F. and the heads were all in the 280 range at about 4 hours on the engine. Testing continues when the weather allows.
