WaiexN143NM wrote:hi all, tom, doug, just curious, where are you using those long rivets, 52 & 62? are they 1/8 in diameter? all i remember is the 48’s during our build.
thanks
michael.
I was inquiring about 5/32 dia rivets for a hole too oversized for a 1/8 rivet (oversized drilling out a bad rivet). The CCP52 is 5/32 dia 1/8 grip.
peter
Peter Hoey SEL Pvt, Comm Glider, CFIG, Pawnee & L19 Towpilot Philadelphia Glider Council Sonex B SNB0021, N561PH, Taildragger, Aerovee Turbo, MGL MX1, First flight Dec 18, 2022 Also built Sonerai IIL N86PH
hi peter, gotcha. try the ace hardware store, most carry the alum, stainless, steel pull rivets. u may want to call first see if they carry them. most stores have them, but some dont here in norcal.
Tail is done and took delivery of the airframe/wing kit yesterday...its game on.
peter SNB0021
Have unpacked the shipment and trying to decide to move forward on the wings or the fuselage (tail is done). Are there any pros/cons for doing one before the other? I am leaning towards doing the wings first...
Daniel is right..........do the wings first as they are easy to store. Depends on how big you work shop is I guess. The RV's I built I always did the tail and then the wings......stored them elsewhere and then the fuse which is a much longer build.
I did the same with my Onex and it worked very well. The Onex wings are only 5 feet long with out the tips and very easy to deal with. The fuse ends up on the gear and then the engine is hung and the panel installed. This is a lot of work and ties up your shop for a long time...........build the wings first.
Gordon......Onex......Hummel 2400....First flight June 17, 2018
When I did my Onex I built the tail feathers first. Two reasons. Smaller components to store, smaller less expensive possible mistakes. The fuselage was next, then the engine and panel and the move to the airport, without wings, was easier. All this took place in my half of a two car garage. The Onex wings are small and short, build fast, and can be transported in a van. I didn't want to store the wings for a year. There were too many changes in the kit during that time. Inventory and check the skins soon after receiving the kit. I had shipping damage to a wing skin that I didn't discover soon enough.
Can anyone offer advice on cutting phenolic block (for the cable guides)?
peter
