Waiex #0056 - N569KM First Flight 4/2/2012
Post stories/images of the first flight of your Sonex, Waiex, Xenos, or Onex here.
Re: Waiex #0056 - N569KM First Flight 4/2/2012
Postby XenosN42 » Mon Jun 18, 2018 12:54 pm
Hi Ed,
You can adjust the brake cable tension where the cable is attached to the lever attached to the brake drum. Just loosen the nut, pull the cable through a bit, and retighten the nut.
-- Michael
-- Michael
OneX N169XE
XenosN42
Postby MichaelFarley56 » Mon Jun 18, 2018 2:45 pm
Hi Ed,
I'll email you with a response to your original questions, but with regards to your brakes, I totally agree with what you've read already. A visual check of the brakes can't hurt just to ensure there's no issues with the shoes and drums (make sure the drums rotate freely outside the shoes), and then like Michael said, you can adjust the brake cable tension so it's a little tighter. This should allow you to get a little more leverage on the brake handle. Try that and let us know how it works for you!
Jabiru 3300A #1706
Postby Ed Perkins » Sun Jul 22, 2018 4:37 pm
Mike, are you at EAA this year? I have brake adjustment questions and MGL V6 Radio issues. Can we talk or get together this coming Wednesday?
Thanks, Ed Perkins, Appleton, WI, Sonex N239KP, 920-358-7242
Ed Perkins
Postby Ed Perkins » Sun Jul 22, 2018 4:54 pm
Michael, I'm bad at catching emails & responses, as you can see. I just found your response to my June message on brakes. Info is helpful. Hope we can meet up on Wednesday. I'm going to be at the cook out at Wayne Daniels place in OSH on this Wed. Will you be there also?
Ed Perkins 920-358-7242
Ed Perkins
Return to First Flights!
