lutorm wrote:Did you ever try the different viscosities? I just noticed that Great Plains recommends 10W-30 (or straight SAE30) for use with their Force One bearing.
lutorm wrote:Hmm... So I just got my Aerovee started after the rebuild (after some troubleshooting, see separate post) and I also have 90+psi (off-scale high) at startup idle. I'm even running Brad Penn 10W-30 for the moment. As the oil warmed up to 120F or so it dropped to the 80s at idle. I guess I'll be taking a second look at my oil plungers, too...
NWade wrote:Which plunger did you check?
Users browsing this forum: Bing [Bot] and 12 guests
