I'd like to take a moment to thank the moderator for allowing this thread on here and to everyone of you for working to keep it civil. For certain there is a lot of passion. I get that but I do trust that everyone will show a bit of patience as we have a very long way to go. My last post wasn't meant to offend in anyway but rather to set up the narrative that it is legal to do what I have done.
At the beginning I said that it wasn't my purpose to change anyone's mind or to argue but rather to answer the question of what justification I had for what I did. I admitted then and again now that i might be completely wrong and that if you do what I did it could get you injured or killed. I also want to offer an apology as many both online and off line are asking for numbers. Perhaps I didn't make clear that this would be quite a journey in going through a lot of information and that it wasn't possible to give it all in one or two posts. I see Mark has posted some stall speed info (thanks) and while I want to look at numbers (data) this time we won't get that far. I suspect that many of you will be able to help me better understand the information I have to share.
So please feel free to reply. You don't have to agree and are more than welcome to disagree. I only ask that you do so in a professional manner. If you have information to share or a better way forward please share. But I ask again that we be adults and resist the temptation to snipe at someone else or show a condescending attitude. I thank you all.
Someone pointed out the factory notes on weight increase:
Additionally, operating at gross weights above our published limits degrades the aircraft's
performance (climb rate, take-off/landing distance, stall speed, etc. may be effected) and
reduces the margin of safety when G-loads are experienced. Airframe components may
also see increased wear or reduced service life as they are subjected to loads for which
they were not designed.
This is absolutely correct. If you raise the gross WITHOUT adding power to compensate, performance will be degraded. Increasing horsepower by >30% will take care of that though! 8~) You will reduce your margin of safety. But the questions are ... how much margin is there? How much am I losing? Is it still safe? Am I comfortable with the trade off?
Check the numbers! The factory has a display wing on the wall that was touted at the builder's seminar many years ago as bending at 9 Gs. Their web site at one time had a page showing the failure test numbers for the main wing. Don’t see it on their site anymore but here is a copy from the Zenith site:
Using these numbers (+9/-4.5) as our baseline we will get +6.0/-3.0 with a safety margin of 1.5 at aerobatic weight. Keep in mind that when doing these calculations the weight of the wings is subtracted as they are “self-supporting.” IIRC the Sonex wing weighs about 70 lbs. each for a total of 140 lbs. That amount is taken from our flight load calculations. Our new aerobatic load limit weight will be (950-140=) 810 lbs. for +6.0/-3.0. What about the slight gross weight increase to 1250 lbs.? This equates to ~ 8% increase. The G-ratings for the air frame at aerobatic weight leaves abundant margins when the numbers are compared to the slightly higher gross of 1250 lbs. Using the 9-G rating attained at aerobatic weight we still have ~+6.6/-3.3 for ultimate loading at the higher gross. (Remember to subtract the weight of the wings from your calculations as they are “self-supporting”). This gives a load limit at 1250 lbs. gross of +4.3787/-2.189. The factory gives two up a load limit of +4.4/-2.2 at 1150 lbs. (although I get +4.8/-2.4) and know that even at their lower numbers the load limit would still be greater than +4.0/-2.0 load limit when the gross is increased by 100 lbs. to 1250 lbs. So the factory numbers agree, by testing, that the airframe retains acceptable margins with a modest gross weight increase to 1250 lbs. & still meets ASTM G-load rating standards for factory built sport planes (+4.0/-2.0) even though that isn’t required for experimental aircraft.
How the FWF weight increase fits in here will be looked at in another section but for now just consider the structural loads that are imparted using a 200 lbs. FWF weight at 6 Gs compared with the loads of a 250 lbs. FWF weight with 4 Gs. Which load stresses the air frame more?
The air frame is stoutly built! A recent poster showed that the FWF weight of the Jabiru 3300 fully installed was 215 pounds & the Corvair at 255 pounds. It was suggested the Corvair adds 20 lbs. to the FWF weight but it’s more like 30-35 lbs. No doubt a VW conversion with steel cylinders, turbo, 2nd oil pump, 2 oil filters, lines, air/oil separator, exhaust wrapping, heat shield, water pump, electric fan, hoses, radiator, coolant, wiring, switches, etc., is near or over the strict FWF limit while the newer/lighter Corvair conversions will be ~15-18% FWF weight increase over the Jabiru 3300. Keep in mind that some additional weight on the nose helps combat the rear CG issues some have experienced when lighter engines are used.
The factory web site has a note about how the accumulation of test data for these aircraft was done i.e. “load testing using procedures prescribed by FAR part 23.” So the wing and the air frame are good to +6/-3 Gs at aerobatic weight.
As it has already been pointed out; the small increase in gross weight has a minimal effect on the tail as long as the CG is correct for the aircraft. It is the main wing that carries the load. My inspector was quite thorough with me in all aspects regarding the numbers I had regarding gross weight W/B & C/G and how I arrived at the numbers I had.
There is so much more that can be given to this one part of the discussion. Again I ask that those that reply please do so in a polite and professional manner.
PS: Apologies for the hurried post and possible bad calculations ... need more coffee!
Dale Williams
N319WF @ 6J2
Myunn - "daughter of Cleanex"
120 HP - 3.0 Corvair
Tail Wheel - Center Stick
171.9 hours / Status - Flying
Latest video:
https://www.youtube.com/watch?v=1VP7UYEqQ-g
