Quite an incredible response to my first posting. I want to thank all for the very civilized responses, great thoughts and information shared.
For sure there are some things I take a bit of a different view on but overall it seems that everyone is nearly on the same page.
I want to clarify that my opening questions were not intended as reasons or justifications for the Corvair install (although some of that data comes up later) but rather I seen these facts as things most builders of these airplanes might like to know but most likely did not. Under no circumstances would I suggest that anyone fly a Sonex over VNE (although Jeremy did that on the Turbo video) or over 1320 lbs.
So as an opening or preface let me put a few more thoughts on the list and see what others believe.
The Sonex line of aircraft exist today because a young man built an airplane he called the Monnett Mini, a.k.a the Mini Messashidt, which was a modification of the Parker Jeanies Teenie. Not only that young man but another builder in the mid-60's purchased a Stits Playboy and modified it by installing a larger engine. Later, he modified the aircraft by installing cantilevered aluminum wings with flaps, creating the RV-1 in 1965. Were these two men showing disregard or disrespect for the designers intent?
I would also ask if it could be said that the factory is showing "blatant disregard for the design limits" of the lowly VW engine by asking an engine designed originally to output 60 HP @ 4400 RPM to now deliver 25% more @ 3400 RPM ... and even further disregard the design by adding a turbo to seek 100 HP from this engine. I understand the upgraded racing parts used to build the engine but the case is basically the same and certainly the heads have less cooling area than before with heavier chamber walls and fins removed to add a second plug. Does this work? Appears it does. Reliably so? It appears that the answer to that is not quite as clear as some would like. I try to focus on safety (as I'm certain we all do) within the limits of my budget and abilities. I have to weigh my choices very carefully and determine, what for me is best.
I did consider that in my airplane I wanted the strongest air frame in my price range along with the most reliable power that I could find in an engine that would work on the air frame I choose. I nearly built a Zenith 601 ... but I digress. So here's some initial information:
1) Many Cleanex pilot fly aerobatics. I don’t.
2) Most flights are just me, fuel, and baggage and are well under 1100 lbs gross.
3) Flying smoothly at 1250 lbs. has proven to have no ill effects on aircraft handling and performance is quite good with 120 HP on the nose.
4) Va speed was reduced.
Here is the preface from the article (please note the disclaimer):
I’ve often been asked why I used a Corvair engine on my airplane and I’ve written many replies. Recently I put on the Builder’s list a set of twenty four (24) extremely compelling reasons why this engine should be considered if you are looking in the area this falls into for power & price. This engine is absolutely, by design, heads and shoulders above anything else in its price range. From crossflow heads to canted valves and the ability to cool itself extremely well, all while being smooth in operation and quite robust by design makes it an exceptional choice for an aircraft power plant.
But the question that was asked that needs to be answered wasn’t about why I put a Corvair engine on this airframe but rather the “justification” for doing so. Many guess at a few of the reasons I did this and some paint with a very broad brush. The purpose of this article is to show clearly that this was not done with any “blatant disrespect” nor was it done in an attempt to fit an engine to an “inappropriate air frame.” There is no intent to criticize or disparage the factory!
Here is the disclaimer: The information I will share in this series is my own opinions, speculations, calculations, and conclusions. I cannot and do not recommend that anyone do as I have done. Following my example could get you injured or killed for which I assume no responsibility. You have been warned. This information is not a license for you to believe that what has worked for me will work for you. I’m not aligned with anyone, or any company. No one has asked me to do this for their profit or their promotion. I’m sharing this so that the “justification” for my personal choice will be known.
Dale Williams
N319WF @ 6J2
Myunn - "daughter of Cleanex"
120 HP - 3.0 Corvair
Tail Wheel - Center Stick
171.9 hours / Status - Flying
Latest video:
https://www.youtube.com/watch?v=1VP7UYEqQ-g![Image](https://encrypted-tbn0.gstatic.com/images?q=tbn:ANd9GcRw5tDDGTpcCKBaL77nlwxIyJCQyRRHWGoB1zY4zUQEq8rSdjmr)
